I recently had a listen to some Alesis M1 Active Mk II monitors at a friends place, I was blown away with how good they sounded in such a small room (smaller than mine) and also recently read the thread by Wolvebain about Active near/mid field monitors suggestions.
I am new to active monitor speakers and would appreciate some suggestions on audio interfaces/DACs that can be used as a sound card and also to control the speakers volume.
The friend with the Alesis used the Focusrite Scarlett 2i2 (http://www.a1sound.co.za/pScarlett-2i2/Focusrite-2-in--2-out-USB-20-Audio-IO-Aluminium-Chassis-Focusrite-Mic-Pre-Amps.aspx).
Are there any other audio interfaces options that I can look at?
