Streamer advice: Naim vs Eversolo
Durban
Hi guys. I am looking to upgrade my streamer and narrowed down to two options. A new Eversolo or a used Naim XD5 XS.
What would be a better buy between the two? I only use Tidal so connections and connectivity are less important to me than sound quality. I find my Focals a bit bright and was looking for something that wouldn’t accentuate that. The Naim actually works out cheaper than the Eversolo, I would imagine it would sound pretty decent, but would I’m concerned it may stop getting version support due to its age which could render it obsolescent.
