Hi all,
So my next project deck is a Lenco B52. The initial plan was to blend the L70 from my last project and the B52 together on my last project, I had some good fortune and the L70 ended up being its own project. Now I have the B52 that has been half restored so I may as well just finish it
I have a few questions
1.) Are there any links to restoring the B52 tonearm? Is it any good?
2.) I have 2 x L75 tonearms, do they fit the same fitting? I cant seem to find any details on either the B52 or L75 arms. I suspect the L75 arm to be a bit longer. If thats the case I would rather keep the B52 arm as I am not really interested in cutting up the B52 top plate.
3.) I accidentally broke the circlip that retains the bottom plate of the spindle when I cleaned it up. If memory serves I think its 5mm, anybody no where I can buy circlips?
