Final attempt
Des Miles
Port Elizabeth
So I've made my final steampunk light! Found an old barometer and decided to incorporate into my design. Definitely my last build, this can be an expensive hobby. The barometer only cost me R100 but the rest of the bits and pieces works out to +/- R1200! This does not include what I payed for a pipe cutter and flaring tool.
Used Curlycat's idea for the switches, they fit and work perfectly (thanks curlycat). Will be using this in my radio room, The 3D lamp gives a nice ambiance to the room.
AND YES!! all sections and the light is properly earthed.
