Was busy over the past few weeks building a schuko multi plug for schuko plugs. I didn't take a lot off pics but planning to build a bigger one to fit a Shelly 1 in it so that you can see the power use and volts on the multi unit and that you can switch it off via die Shelly cloud app. Run out off space inside the wood box when all the wiring was installed.
On the leads, my shipment of IEC, schuko and figger 8 plugs arrived. Cable I used is shielded strained 3 x 2.5mm LAPPkabel and Helukabel. PRoP plugs used for the main supply. The figger 8 cable I made for my BlueSound Node streamer. Shielded part is connect on the earth part at the input side.
Will post more pics with the next cable.
