Amp chassis finsih
Mongoose
Hey guys. The QSC chassis I have at home has some rust patches around the front and rear panels that I would like to get rid of.  Sanding of the chassis to remove the existing paint and rust is easy enough. Spray painting a few coats of primer and then a few coats of matt black will work, but I then loose the texture of the original amplifier. And this is what I would like to achieve. Somehow it has a industrial feel to it. To give you guys an idea of what it feels like,  Its like a 320 grit sandpaper. Any ideas on how to achieve this in matt black?
Cheers
