Hi guys
I have a B&W AS6 subwoofer and the driver is looking a little tired.
Was wondering if I could replace the driver with a JBL GT5-12.
The B&W AS6 specs as follows
Power rating : 100W RMS into 5 ohms continuous
Frequency response : 30Hz - 40 / 140Hz +/- 3dB
Dimensions [ W x D x H ]: 450 x 455 x 508mm
2 X 60mm ports
Is a 5ohm spec unusual ?
JBL GT5-12 specs
Power handling, RMS 250W
Power handling, peak 1100W
Frequency Response 23Hz ? 450Hz
Sensitivity 93dB
Impedance 4 ohms
Cone Polypropylene woofer cone
I-beam basket Yes
Progressive spider Yes
Hi-roll rubber surround Yes
Mounting Depth 164mm (6-7/16")
VOICE-COIL DC RESISTANCE: REVC (OHMS) . . . . . . 4.00
VOICE-COIL INDUCTANCE @ 1KHZ: LEVC (MH) . . . . . . . 1.26
DRIVER RADIATING AREA: SD (IN2) . . . . . . . . 82.15
SD (M2) . . . . . . . 530.00
MOTOR FORCE FACTOR: BL (TM) . . . . . . . . . 15.2
COMPLIANCE VOLUME: VAS (FT3) . . . . . . . . . 1.9
VAS (LITERS) . . . . . . 54.2
SUSPENSION COMPLIANCE: CMS (μM/N) . . . . 135.00
MOVING MASS, AIR LOAD: MMS (GRAMS). . . . 223.00
MOVING MASS, DIAPHRAGM: MMD (GRAMS) . . . 216.00
FREE-AIR RESONANCE: FS (HZ) . . . . . . . . 29.00
MECHANICAL Q: QMS . . . . . . . . . . . 6.39
ELECTRICAL Q: QES . . . . . . . . . . . 0.64
TOTAL Q: QTS . . . . . . . . . . . . 0.58
MAGNETIC-GAP HEIGHT: HAG (IN) . . . . . . . . 0.315
HAG (MM) . . . . . . . . 8.00
VOICE-COIL HEIGHT: HVC (IN) . . . . . . . . . 1.43
HVC (MM) . . . . . . . . 36.4
MAXIMUM EXCURSION: XMAX (IN) . . . . . . . . 0.56
XMAX (MM) . . . . . . . 14.2
2 X 60mm ports
JBL GT5-12 specs
Sensitivity 93dB
Impedance 4 ohms
I-beam basket Yes
