Moog
The foam surrounds of my little and beloved Heybrook HB1 speakers have suffered from rotting and will need to be replaced or i may need to replace the 8 inch drivers altogether. Although replacing the foam surrounds is a cheaper option than to change the drivers, i am concerned that the foam surrounds that available may not exactly match the foam originally used and if the speaker assembly is not accurately aligned centrally such that the voice coil is perfectly located in the magnet gap, any deviation will result in increased distortion and possibly buzzing as the voice coil rubs against the edges of the magnet gap.
Can someone recommend a speaker repairer in Johannesburg or Pretoria who can replace the foam surrounds properly. The original drivers are the Vifa brand and i am not sure whether they are still made. My other thought is to replace the drivers completeley with a ScanSpeak driver of the same spec, but i am not sure about the cost.
The 8 inch driver has the following specs:
Technical Data:
Frame diameter: 215mm
Sensitivity (2.83v/1m): 90dB
Nominal impedance: 8 ohm
Frequency range: 25Hz-3kHz
Free air resonance: 25Hz
DC resistance (Re): 5.6 ohm
Voice coil inductance (Le): 0.9mH
Effective piston area (Sd): 231.0cm?
Moving Mass (Md): 16.5g
Force factor (BL): 5.2Tm
Qms: 4.9
Qes: 0.82
Qts: 0.7
Vas: 81L
Voice coil diameter: 25mm
Nominal power handling: 80w
Physical Sizes:
Overall depth (front of frame to rear of magnet): 78mm
Flange thickness: 4.5mm
Fixing holes: 4 x 5mm diameter on 206.5mm PCD
Cutout diameter: 190mm
Any helpful hints will be appreciated.
Technical Data:
Qms: 4.9
Qes: 0.82
Qts: 0.7
Vas: 81L
Physical Sizes:
