Rega Planar motor PCB capacitors
mocodo
Pretoria
Hi All, I'm  going to try upgrade my old power supply for a planar 2. Need some help selecting capacitors.
I have found links to the ones I think are correct. Please could someone confirm if I'm on the right path or suggest the correct spec'd ones. I'm not sure which tolerance, DC voltage, AC voltage application type etc etc to choose.
1. 220n X2 - https://www.digikey.co.za/product-detail/en/panasonic-electronic-components/ECQ-UAAF224M/P14781-ND/2674013
                  or
                  ??? Suggestions
2. 120nK400 - https://www.digikey.co.za/product-detail/en/panasonic-electronic-components/ECQ-U2A124ML/P11006-ND/295852
                      or
                      https://www.digikey.co.za/product-detail/en/panasonic-electronic-components/ECQ-E4124JF/P14571-ND/331684
                      or
                      https://www.digikey.co.za/product-detail/en/panasonic-electronic-components/ECW-F4124HL/P12095-ND/585162
                      or
                      ??? Suggestions
