Raspberry Pi 2 Kodi and Squeezelite
scrarfussi
Midrand
i have created a image this is for raspberry pi2.
The unit boots straight into kodi and soa. So kodi audio is output from hdmi
and squeezelite whatever usb dac you may have .
" root password is root"
" user password is user"
you need the user account if you want to make changes to SOA
use w32diskimager to write image to disk
you will need a 8gb card or more . i only had a 8gb card at the time
http://sourceforge.net/projects/win32diskimager/
plug card into device
boot up Hdmi out should display  Kodi
if you wanna use squeezelite , then you use advanced ipscanner
http://www.advanced-ip-scanner.com/index4.php?utm_expid=62919999-12.1FzOM1p7Rsm2h9tPzp1oZQ.4&utm_referrer=https%3A%2F%2Fwww.google.co.za%2F
if you have android use a app called fing to get the ipaddress of the unit .
Enter ipaddress into web browser SOA page will pop up
go to squeezelite player you can change the name and audio device to your dac
if you have a wireless dongle you can also setup wifi
https://www.dropbox.com/s/l0r6me7csx2cvck/soakodiimage8gb.7z?dl=0
