maximum vs dynamic power output
doug
kloof durban
Hi every forumite
Please  can some please explain what the difference is between maximum and dynamic power ratings on amplifies
As you guy and gal's know I recently purchased a new intergrated amp yamaha a-s 801
Here is part of the spec sheet for the amp. I'm running Rx8 wich are rated @ 4 Ohms. How much juice is going to said 4 Ohms
Maximum Power (4 ohms, 1 kHz, 0.7% THD) 160 W + 160 W
Rated Output Power (8 ohms, 20 Hz - 20 kHz, 0.019% THD) 100 W + 100 W
Power / Channel (8 / 6 / 4 / 2 ohms) 140 / 170 / 220 / 290 W
Damping Factor (8 ohms, 1 kHz) 240
CD 200 mV /47 kilohms Sensitivity / Impedance Phono MM 3.0 mV / 47 kilohms
Frequency Response CD, etc. to Speaker Out 20 Hz – 20 kHz: 0 ? 0.5 dB
CD, etc. to Speaker Out, Pure Direct on 10 Hz – 100 kHz: 0 ? 1.0 dB
RIAA Equalization Deviation Phono MM ?0.5 dB
Total Harmonic Distortion CD, etc. to Speaker Out 0.019% (50 W / 8 ohms)
(20 Hz – 20 kHz) Phono MM to Rec Out 0.03% (2.5 V)
Signal-to-Noise Ratio CD, etc. (200 mV, input shorted) 99 dB
(IHF-A Network) CD (CD Direct on) 104 dB
Phono MM (5 mV, input shorted) 82 dB
Residual Noise (IHF-A-Network) 40 ?V
Channel Separation CD, etc., input 5.1 kilohms (1 kHz /10 kHz) 65 db / 50 db
Bass boost / cut at 20 Hz ?10 dB
Tone Control Characteristics Bass turnover frequency 400 Hz Treble boost / cut at 20 Hz ?10 dB
Treble turnover frequency 3.5 kHz
Support Audio Sample Rate Digital in (coaxial / optical) 192/176.4/ 96/88.2/48/44.1/32 kHz
USB (type B) 384 /352.8 /192 /176.4 / 96 /88.2/48 /44.1 kHz
PCM Word Depths 32 / 24 / 16-bit
DSD   2.8224 / 5.6448 MHz
GENERAL SECTION
Standby Power Consumption 0.5 W
Dimensions (W x H x D) 17-1/8” x 6” x 15-1/4”
Weight 26.7 lbs.
Thanx for your replys
