How to connect a subwoofer?
Arc
Pretoria
I can't get a clear answer on this via my internet searches.
I have a B&W 608 which has 2 line outs?(Inputs?) L + R.
As I understand it, newer subs has one clearly marked as LFE and you use the one cable to connect it to the AVR. In Older AVR's you use both as its using a stereo signal and connect both?
Or with dual subs you would use L on the one and R on the other.
So, Im not sure my sub is running on the LFE channel of the AVR and should I connect 2 cables?
Thanks
