Peei
Hi, don't you hate it if somebody tells you 'make me an offer?'
A friend of mine has a Marantz 2220B, Marantz 6100TT, and AR2ax loudspeakers he is not using. I asked him if he wants to sell it. THEN 'make me an offer' I dont have a lot of money but I want them.
Marantz2220B, Exterior has only tiny scratches, averything works perfectly except some of the little lights
Marantz Turn Table model 6100. The lid has normal wear and tear scrarches + 3 bigger ones of about 8cm each. The rest of the unit is dusty but works perfecly with not much time on the needle
The AR2ax have a lot of wear on the outside. And the speaker cloth needs to be replaced. All the surrounds show signs of use and probably needs replacement but there is no holes. The crossover dials at the back is very scratchy but work
