Help with a 5Kw good system both cost wise and product wise
Chaperone
South Africa
Good day
Currently, I have a 3Kw system with Lead Acid batteries, I want to upgrade it to a 5KW with a lithium battery no solar as it is not allowed at my complex probably will put it in future if things change.
I did some research and seems the more I research the more confused I get. So I need some valuable help on the system to choose considering durability and cost.
Option 1 low cost
Lux Power Inverter 5KW Off Grid (LUX-SNA5000WPV) R13800.00 or KODAK Solar Off-Grid Inverter King with UPS 5kW 48V R12600.00
Revov 2LIFE-R9-UBMS-R100-5.1 R28000.00 or Dyness 5.12 R27000
Option 2 medium cost
Lux Power: Inverter 5KW Hybrid LV Single Phase (LUX-LXP5K-LV) R23000 or use
HUBBLE AM-2 5.5KWh 51 Volt Lithium R32660.00 or the above batteries
Option 3 High cost
Deye: 5Kw Single Phase Hybrid Inverter (SUN-5K-SG01LP1-EU) R26000.00 or Sunsynk 5kW 1P Hybrid PV inverter 48V R28000
Sunksynk Battery LFP Wall Mount 5.32Kwh 51.2V Extended Sunsynk Warranty R34000.00 or above batteries
The confusion I have is whether there is any benefit to going with the High-cost option rather than the low cost. I went through some threads here and some people were saying the medium option is a pretty solid one others were saying the high cost one is the way to go. I would not want to buy the high cost just for the brand names only.
