DIY Enclosures
Heinrich
Centurion ,Gouteng
finally i am ready to take orders for DIY amp/pre-amp enclosures.
there are 3 different sizes.
they are all made of a top and bottom piece with holes where the front and back should be.
to fill the rear holes there are aluminium plates .
2 different plates for the small case and one plate for each of the 2 bigger cases.
all the back plates have a cut out for a standard IEC socket(power).
the 2 options for the smallest case: one with 10 RCA holes for a pre-amp and one with 6 RCA holes for a phono amp.
the 2 larger back plates has got no extra holes except for the IEC socket hole.
as far as the front is concerned , i have no solution yet. will work on that.
all cases are sandblasted and painted satin black.
standard HiFi component width and depth.
65mm high  R680
95mm high  R720
135mm high R750
65mm bacplate pre-amp R80
65mm bakplate phono preamp R80
95mm backplate (iec socket only) R90
135mm backplate(iec socket only)R95
all box dimensions are the sam except for the height .
some pics of my own SRPP+ built into such a case.(case in pic is 65mm)
once i have enough people interested to make my efforts feasable,i will order a batch witch will take more or less 3 weeks for delivery once ordered.
Heinrich.
