Arcade Gaming Machine rebuild - Edging
MorneDJ
Garsfontein, Pretoria
Hi All,
I am busy to rebuild an old gaming machine. Got a cabinet for cheap on OLX, but the guy for some reason decided to paint it this horrible green and pink.
The cabinet is mainly constructed with chipboard (sides) with MDF and wood as support. It is very sturdy. Originally the chipboard was covered with this plastic or vinyl covering/decals that took a beating through the years, likely the reason the guy painted it.
The edging however is in a real bad condition, the red original painted black then again pink ... So I either need to replace it or use body filler and sand, sand, sand.
Edging:
The chipboard edge:
I am leaning towards using some sort of 2-part epoxy body filler to do the edges. Any suggestions?
Morne
