Author Topic: Sanyo RD 5350 Stereo Casette Deck  (Read 807 times)
Offline juventino
  • Trade Count: (+18)
« on: August 26, 2017, 08:02:27 PM »
To the tape deck Gurus picked the below up.
Need to pick some brains here for assistance,  with or without a tape if I push play it goes for 3 seconds then stops.
What could it possibly be? Or too many things could be the cause to give a diagnosis?
Sent from my SM-G935F using Tapatalk
Time to get back to when I enjoyed listening......no more upgrading, more of a headache than a pleasure
Offline HBAutomation
Re: Sanyo RD 5350 Stereo Casette Deck
« Reply #1 on: August 26, 2017, 08:45:02 PM »
No clue.  Very pretty though!
When You Come to a Fork in the Road, Take It!            [Yogi Berra]
Offline skollie
  • Cableth make no differenth. Ith all in the plugth
    • Blue Angel
« Reply #2 on: August 26, 2017, 08:47:16 PM »
Check and change the belts.
skollie
If you don't like my principles, I have others - Groucho Marx
Offline juventino
« Reply #3 on: August 26, 2017, 08:50:20 PM »
skollie
Is it a difficult job for a complete noob
Offline gapco
« Reply #4 on: August 26, 2017, 09:38:06 PM »
Does the deck fast forward and rewind the tape without stopping? Check if the tape counter works when you try this.
Give me an espresso and nobody gets hurt....
Offline Steerpike
  • Forum Moderator
    • Toybox
« Reply #5 on: August 27, 2017, 12:21:34 AM »
Agreed.
They usually have a motion sensing system on the right reel hub, or counter pulley. If a belt (or rubber idler wheel) has failed, the reel hub does not turn and the mechanism 'thinks' the tape is at an end.
Not difficult to replace, but it sometimes involves a lot of disssembly - many things to remove before the belt can be got in. And, getting the right replacement can be tricky: with no official service and parts support any longer, you have to buy a generic belt, and that means YOU have to measure the size, which you cannot do from measuring an old belt that is broken or streched. You need to make a 'test belt' from cotton thread to check the size.
The other common problem is grease that goes hard and jams up the moving levers in the mechanism. Turpentine is good for cleanng that.
Offline juventino
« Reply #6 on: August 28, 2017, 09:11:37 AM »
I did Fast Forward and the counter did work but it did pull out the tape.
Agreed.
The other common problem is grease that goes hard and jams up the moving levers in the mechanism. Turpentine is good for cleaning that.
So this is not for the novice then......who are the tape deck masters in JHB or not worth the fix?
Its not something i would use often so if not fixed then will put on the shelf for display where it was with the previous owner for over 15 years.
Offline juventino
« Reply #7 on: September 07, 2017, 03:18:14 PM »
So this beauty was given a once over and is working 100%
Took it home and listened to 1 track on an old mix tape that had lying around from days gone by.
Now to see if i can find some original tapes and sit back an enjoy.  :dance:
Online Ampdog
« Reply #8 on: September 16, 2017, 06:45:13 PM »
Juventino!
Came late to this. I have had such a deck for 40 years now, works flawlessly but I did 'service' occasionally, seeing as how Pretoria is not the cleanest city in the country.
Can you tell what was the matter then?
Mine is/was not used that regularly but still has original belts. I modified it somewhat to give a goodly 16 KHz response with ferrotape. At a time I often used it for mixing-'splicing' voice and music used in prsentations, as the pause function really has an instant start when held just "off". The 'Recording Mute' facility also came in handy. I guess time to also go over once again and 'restore' whatever is lacking.
PS: The festoon meter lamps are difficult to get hold of.
Offline juventino
« Reply #9 on: September 18, 2017, 11:00:45 AM »
Juventino!
Hi there,
All it needed was a clean, all belts were still in good condition and all the lamps all working. The level meters needed a slight adjustment as the left channel ( i think) was slightly off.
Sounds great and very surprised it only needed a clean considering it has not been switched on for 20 years
Offline christowp
« Reply #10 on: September 20, 2017, 08:43:34 PM »
So who worked the magic? The noob?
Offline gapco
« Reply #11 on: September 22, 2017, 11:53:03 AM »
I worked on the deck. Simple job because the unit had been well stored and never opened before.
