Philips HS 510Q turntable?
alternativeroute
Has anyone heard of a Philips HS 510Q turntable before?
I picked up this one from my local cash crusaders. I got them to turn it on in the shop and it turns perfectly. I got them down from their stupid price as the cart was missing a stylus. Fortunately I had a new stylus at hand.
What is interesting with this one is that it has two options for speed; you can either activate quartz lock or you can use it without quart lock and the speed/pitch adjuster. With the quartz lock activated the pitch/speed slider is disabled...
The table is semi-automatic in that the arm will return at the end of the record (or during if you 'reject' the play)...
I cannot find any information at all about this table... Anyone know anything about it? Was thinking that perhaps Philips made it under licence....
Philips HS 510Q - close Up by arclients, on Flickr
Philips HS 510Q - Quartz lock or Not by arclients, on Flickr
Philips HS 510Q - side view by arclients, on Flickr
Philips HS 510Q - top Closed by arclients, on Flickr
Philips HS 510Q - top Open by arclients, on Flickr
