Van Den Hul Magnum 1.2m pair
croak
R.I.P. 28 June 2021
Classic van Den Hul MC The Magnum speaker cable 1.2 metre pair.
Ends freshly stripped and soldered using Cardas Quad Eutectic solder.
Plugs used are The Chord Company bananas.
This cable suits the cable agnostic audiophile with mono amplifiers.
It?s a trusted brand.  It?s of a gauge in excess of that required for zero influence theories.  Silver plating preserves the copper from atmospheric influence so the well soldered cable with good solid plugs will be stable for years.
This is the earlier non hybrid version.
R1200.00
Material value of cable and plugs today is over R3000
