Using Marantz SA-KI-Pearl CD player as DAC
Zealot
Port Elizabeth
Hi guys
This unit houses a "Cirrus Logic CS4398, a 24-bit/192kHz device that also includes a DSD processor that doesn't decimate the datastream, while maintaining DSD's native sampling rate of 2.8224MHz" "Thanks to its B-type USB input on the rear panel, the PC will recognize it as an audio card." as per Marantz
Do you think this would be a worthwhile "upgrade" to use as a DAC between a PC and pre-amp?  70% MP3 30% hi-res files.
Thanks for your time.
