I'm hoping you guys can help, I have a small set of Tannoy speaker (I forget the model). They have a 4" full range driver and a tweeter. Unfortunately the tweeters are blown and I need replacements.
I've tried PQ Sound but unfortunately the terminals stick out too far to fit the pre-cut hole in the box.
Does anyone know of a tweeter with a terminal area no wider than 30mm?
The below fitted perfectly apart from the terminals which stick out a ridiculous length.
http://www.pqsound.co.za/index.php?main_page=product_info&cPath=17_114&products_id=1147
Looking for 40-60 watt
