Sofar Solar // Rentech
Kshah
Westville Durban
HI guys anybody here got experience with Sofar Solar?
They are being marketed here under the Rentech brand which is owned by the Manufacturers of Willard/Sabat batteries.
I could get a fantastic deal here and its a few k cheaper than the best in class i.e. Sunsynk and Deye.
I have chatted with Gerlach on this but he says that it looks like it check all boxes he doesn't have any first hand experience with these.
https://www.takealot.com/solar-inve...00-ep-on-grid-nrs97-5000w-5000va/PLID91370369
Description​
General Features:
-On grid and off grid – NRS097-2-1 Certified
-Built-in zero export function
-EPS function, switching time is less than 10ms
-Lead acid or lithium battery – With lithium BMS comms
-Configurable operating modes – Parallel up to 6 units
-Integrated fanless self-recognition heat dissipation design
-Outdoor IP65 design
-Wi-Fi and Solarman remote monitoring included
-Parallel Inverter – up to 6 units
What's in the box
1x SofarSolar HYD-5000-EP ON-GRID NRS97 5000W/ 5000VA
1x User Manual
1x Rear Panel
2x Pv + Input Terminal
2x Pv - Input Terminal
2x Metal terminals secured to pv+ input power cables
2x Metal terminals secured to pv- input power cables
1x BAT- input terminal
1x BAT+ input terminal
x3 M6 hexagon screws
x4 M8*80 expansion bolts used to secure the wall mount bracket to wall
1x AC Grid connector
1x Load output connector
1x Link output connector
1x 8 pin terminal matching terminal resistance (parallel system)
1x Split core current transformer
1x COM 16pin connector
1x DDSU666 single phase electronic type guide rail mounting electric energy meter (optional)
1x Warranty Card
1x Quality Certificate
