Sennheiser HD515 lockdown fix
Samayanaya
Pretoria East
My awesome headphones failed me... not electrically (the drivers work perfectly) the ear pads foam disintegrated completely... As in it became a fine powder that sticks everywhere. Horrible feeling between your ears and head  :cr@p:
The local Sennheiser people says that the earpads are obsolete for HD515 so I will order on Amazon when the Lockdown is over.
In the meantime I decided that it needs a temporary fix. Just until I can order a new set.
I found a piece of plastic foam. Its a bit hard but not too bad.
Made a CAD (Coukie Assisted Drawing) drawing on the foam
Cut with precision scissors
The two new foam pads are in and it works... It is acceptable  :2thumbs:
Lockdown fix done  :2thumbs:
