Not quite DIY audio, although the 2-stroke engine is music to my ears!
I just bought a 2nd hand boat but the windshield has cracked around one of the points where it is fixed to the boat with a screw.
Is there an easy fix like simply glueing the small piece through which the screw goes to the rest of the windshield?
What type of glue would you use? I think it is possibly perspex, blue/purple tint you normally get on boat windshields but I can't be certain.
Unfortunately the boat is kept at the dam so I will only be able to take a picture over the weekend, but if there is an easy fix I would like to try it over the weekend when I go to the boat again.
