I had some issues with my Linn Basik running a bit slow. After reading that a belt that is too thin will cause a turntable to run slow, I tried the original belt again. Even though it is a little less tight than ideal it is a bit thicker and the turntable now runs exactly at the correct speed. Does anyone know where I can find an original Linn belt (LP12 and Axis use the same belt)?
