Battery Runtime Calculator
Thor
Bellville
I built a battery runtime calculator, let me know if you want me to add any specific UPSes or Inverters.
I always work out on a piece of paper for friends and family, so decided to just build a tool instead I can send them.
https://erikthiart.com/tools/calculate-battery-runtime-using-watts.php
In essence, you just plug in your battery spec ( Voltage and Ah ) and the load size.
Let me know if there is anything I can do to improve it.
