Yamaha Subwoofer -RSW300 YST to Yamahe amp A-S701
OBELIX
Northriding/Randburg
In search of knowledge or experience please: The amp has ONE RCA output for sub & the sub has TWO RCA inputs (L =MONO &R). If I use on cable from the amp (there is only one RCA)to the designated L on the sub (It says there L=MONO)...is the BASS from both channels transmitted into the sub or only from one channel -the Left one) ? See attached diagram of the recommended connections from the Yamaha Sub.
Last but not least: Is it advisable or can one without audio loss lengthen an RCA cable to a SUB by means of RCA connectors? e.g 5m + 3m ( NOT LONGER !!) ?
  • Sub Connect. scan.pdf
