RØDE Professional USB-C microphone - made in Australia
chrisc
Plumstead, Cape Town
Received from a newly-converted audiophile friend in Perth. He is now an expert and bought one of these. Can get earlier models from Paul Bothner Music for around R2800,00
The NT-USB+ is a professional USB microphone that makes capturing studio-quality sound simple. It excels in a wide variety of applications, from recording music to podcasting and streaming.
Delivers pristine audio quality with ease of use and premium features,
Key Features:
Professional USB microphone
Studio-grade condenser capsule with tight cardioid polar pattern
Ultra-low-noise, high-gain Revolution Preamp
Powerful APHE audio processing accessible via RØDE Connect, RØDE Central and RØDE Reporter
High-power headphone output with zero-latency monitoring and versatile controls
USB-C connectivity with high-resolution analog-digital conversion
Detachable pop filter and desktop stand included
Class-compliant USB output that works seamlessly with computers, smartphones and tablets (iOS and Android)
Designed and made in RØDE's state-of-the-art facilities in Sydney, Australia
Studio Sound at Home
The NT-USB+ harnesses the pristine audio quality of a professional condenser microphone and combines it with the convenience of USB connectivity, making it the perfect solution for recording studio sound at home. It features a studio-grade condenser capsule with a tight cardioid pickup pattern, so your recordings are always rich and focused, and its ultra-low-noise, high-gain Revolution Preamp™ and high-resolution analog-digital conversion deliver incredibly clear sound.
Versatile and Portable
Like all great studio microphones, the NT-USB+ excels at everything from recording vocals to voice-overs, guitars to podcasts. Whether you're a musician, streamer, podcaster or a professional working from home, the NT-USB+ delivers high-definition audio in any application. It is also plug-and-play compatible with smartphones and tablets, giving you a high-quality recording solution that you can take with you anywhere.
Just Plug in for Professional Audio
Capturing professional-quality audio with the NT-USB+ is easy – simply plug it into your computer, smartphone or tablet and you're ready to go. Want to take your recordings to the next level? The NT-USB+ features powerful internal DSP for adding advanced audio processing and effects to your voice, unlocked with the free RØDE Connect podcasting and streaming software, RØDE Central companion app for desktop and mobile, RØDE Reporter or UNIFY (subscription required).
All-In-One Desktop Studio
The NT-USB+ comes with everything you need to start recording right away, including a desktop stand for positioning it perfectly and a high-quality pop filter to keep your recordings clean. It also features a zero-latency headphone output with dedicated volume and mix controls so you can monitor your audio loud and clear, free from echo or delay.
RØDE Central is an easy-to-use desktop and mobile companion app for the NT-USB+ that allows you to unlock the on-board processing, including the compressor, noise gate, high-pass filters and the legendary APHEX® Aural Exciter™ and Big Bottom™. You can also update the device firmware.
Note: OS Requirements – MacOS 10.14 or later; Windows 10 Version 1803 or later; iOS 14 or later; Android 9.0 or later.
Professional USB Microphone
The NT-USB+ is a professional USB microphone that makes capturing studio-quality sound super simple. Building on the legacy of the legendary NT-USB with next-generation features, it excels in a wide variety of applications, from recording music to podcasting and streaming. Delivering pristine audio quality with incredible ease of use and premium features, the NT-USB+ will have you sounding like a pro in seconds.
Capturing professional-quality audio with the NT-USB+ is incredibly easy – simply plug it into your computer, smartphone or tablet and you're ready to go. Want to take your recordings to the next level? The NT-USB+ features powerful internal DSP for adding advanced audio processing and effects to your voice, unlocked with the free RØDE Connect podcasting and streaming software, RØDE Central companion app for desktop and mobile, RØDE Reporter or UNIFY (subscription required).
RØDE Central is an easy-to-use desktop and mobile companion app for the NT-USB+ that allows you to use the on-board processing, including the compressor, noise gate, high-pass filters and the APHEX Aural Exciter and Big Bottom You can also update the device firmware.
