Hi,
I was just wondering what everyones opinions on Home Theatre cables are...
For example, I'd like to buy some component video cables, and the prices vary from R90 to R500+. :shock: Should I go for the R90 Zakspeed cables, or more expensive R500 AR cabels? Will I see a difference?
Has anyone ever noticed a difference between cheaper vs more expensive cables? For audio aswell... Ever heard an improvement from an expensive Digital Co-ax?
BTW, by cheap cables, I am not refering to the really thin ones that com with a system which opten make bad contact and break.
Thanks,
Greg
Thanks,
Greg
