Marantz remote conflict with Primare amplifier
rotorbug
Durban
I purchased a used Primare I22 amplifier.
The Marantz SA14 CD player remote unfortunately changes the Primare input or puts the Primare into standby.
Obviously both manufacturers using same IR code.
Only way around the issue has been to disable the IR front receiver via the menus in the Primare. So I have to change the volume manually on the Primare.
Anyone had similar issues and found any other work around for the issue.
I am waiting for a response from Primare via Skye Audio, the SA distributor.
