Electric car argument
chrisc
Plumstead, Cape Town
An academic friend (he is head of Dept of Music at Berkley) in the US who is what you might call technologically challenged has waded into the electric car debate and forwarded me some startling conclusions
Here is his first email:
Interesting Take on Electric Cars
This is for Engineers out there, surely there should be a rebuttal to this article.  Say it isn't true!
As an engineer I love the electric vehicle technology.  However, I have been troubled for a longtime by the fact that the electrical energy to keep the batteries charged has to come from the grid and that means more power generation and a huge increase in the distribution infrastructure.  Whether generated from coal, gas, oil, wind or sun, installed generation capacity is limited.  A friend sent me the following that says it very well.  You should all take a look at this short article.
INTERESTING -  ONE OTHER QUESTION. IF ELECTRIC CARS DO NOT USE GASOLINE, THEY WILL NOT PARTICIPATE IN PAYING A GASOLINE TAX ON EVERY GALLON THAT IS SOLD FOR AUTOMOBILES, WHICH WAS ENACTED SOME YEARS AGO TO HELP TO MAINTAIN OUR ROADS AND BRIDGES. THEY WILL USE THE ROADS, BUT WILL NOT PAY FOR THEIR MAINTENANCE!
In case you were thinking of buying hybrid or an electric car:
Ever since the advent of electric cars, the REAL cost per mile of those things has never been discussed. All you ever heard was the mpg in terms of gasoline, with nary a mention of the cost of electricity to run it  . This is the first article I've ever seen and tells the story pretty much as I expected it to .
Electricity has to be one of the least efficient ways to power things yet they're being shoved down our throats.  Glad somebody finally put engineering and math  to paper.
At a neighborhood BBQ I was talking to a neighbor, a BC Hydro executive.  I asked him how that renewable thing was doing.  He laughed, then got serious.  If you really intend to adopt electric vehicles, he pointed out, you had to face certain realities.
For example, a home charging system for a Tesla requires 75 amp service.  The average house is equipped with 100 amp service.  On our small street (approximately 25 homes), the electrical infrastructure would be unable to carry more than three houses with a single Tesla, each.  For even half the homes to have electric vehicles, the system would be wildly over-loaded.
This is the elephant in the room with electric vehicles.  Our residential infrastructure cannot bear the load.
So as our genius elected officials promote this nonsense, not only are we being urged to buy these things and replace our reliable, cheap generating systems with expensive, new windmills and solar cells, but we will also have to renovate our entire delivery system!    This latter "investment" will not be revealed until we're so far down this dead end road that it will be presented with an 'OOPS...!' and a shrug.
If you want to argue with a green person over cars that are eco-friendly, just read the following.  Note: If you ARE a green person, read it anyway.  It's enlightening.
Eric test drove the Chevy Volt  at the invitation of General Motors and he writes, "For four days in a row, the fully charged battery lasted only 25 miles before the Volt switched to the reserve gasoline engine."  Eric calculated the car got 30 mpg including the 25 miles it ran on the battery.  So, the range including the 9-gallon gas tank and the 16 kwh battery is approximately 270 miles.
It will take you 4.5 hours to drive 270 miles at 60 mph.  Then add 10 hours to charge the battery and you have a total trip time of 14.5 hours.  In a typical road trip your average speed (including charging time) would be 20 mph.
According to General Motors, the Volt battery holds 16 kwh of electricity.  It takes a full 10 hours to charge a drained battery.  The cost for the electricity to charge the Volt is never mentioned  , so I looked up what I pay for electricity.  I pay approximately (it varies with amount used and the seasons) $1.16 per kwh. 16 kwh x $1.16 per kwh = $18.56 to charge the battery.  $18.56 per charge divided by 25 miles = $0.74 per mile to operate the Volt using the battery.  Compare this to a similar size car with a gasoline engine that gets only 32 mpg.  $3.19 per gallon divided by 32 mpg = $0.10 per mile.
The gasoline powered car costs about $20,000 while the Volt costs $46,000-plus.  So the American Government wants loyal Americans not to do the math, but simply pay three times as much for a car, that costs more than seven times as much to run, and takes three times longer to drive across the country.
My response:
Some manipulation of the facts here I feel
I'm basing my reply on a friend who has been driving an electric Renault in France since August 2017
Europe and South Africa have a 220 volt mains reticulation system and most houses are equipped with a 60 amp circuit-breaker.  If you have a single-phase supply, this gives you 13 800 watts to use.  If you have 3-phase. then you have 41 400 watts
Electric car chargers do not have to run at top capacity.  You can elect to restrict the power to the charger to 15 amps.  This is what the lady in France does at home.  At the university where she works, there are "fast charging stations" which provide 80 amps in 20 minute bursts.  This will charge a battery which is down to 75%, up to 100% in 20 mins.  In other words, it will replace 25% of the battery capacity in 20 mins.
When she gets home, every second or third night, she plugs in the garage charger.  This will replenish her car to 100% in 9 hours, using less than 15 amps
The dash has a state of charge meter clearly labelled in Green (ok), Yellow (adequate) and Red (charge before 30km).  She has never had the battery more than 2/3 the way down and within the yellow.  She says the maximum she travelled once was from Paris to Geneva, about 540km.  She stopped at a charging station at the 340km mark for 30 mins and had lunch
The Renault ZEN's price was subsidised and cost her 24000? which includes a 6000? subsidy.  She received 17000? for her BMW 116i
My cousin in Leicester has an electric Volvo.  She reckons her power bill increased from ?6000 to about ?6600 a year.  She pays ?49 a month to lease the car.  Far less than the petrol which is now ?1.55 a gallon
The other very important aspect is that electric motors are 98% efficient, whereas internal combustion engines are 22% efficient and emit pollutants in the form of particulants
An electric car has 2000 components
An internal combustion engine car has 18000 components and requires regular servicing and disposal of contaminated lubricant
A viable alternative is a hydrogen-powered fuel cell electric supply.  There are quite a few of these in Switzerland
Have I missed some important facts?
