Dstv Help
Anton
Pretoria
Hello all ....
My Dstv was working fine without any problems , then the one day i had a small flooding and the dstv decoder power supply was lying on the ground in the water
My plugs on the db board did trip , so i tried to dry the power supply but it was dead and i bought a new one
i Installed the new one and now i get a error of E38-42 , but only on channel 101 , 202 , and i think two other channels....so i thought it could be the LNB and also bought a new one but it is still the same
i Am using two decoders with dualview , both decoders are doing the same so it cannot be that the decoder got damaged , the one decoder is in another room and was not involved in the flooding
All that dstv is saying is check the signal and wires but it was working fine before the flooding incident?  , the best i could get it is about 86 strength and 96 quality
So not sure where the problem might be ...?
Any advice will be appreciated
Thanks
