- Joined
- Dec 26, 2011
- Messages
- 850
- Reaction score
- 71
Project space for the my DIY R-2R dual-mono DAC project, comprising of two Soekris dam1021 Rev 4 (0.012% resistor version) DAC boards, dual independent AC power supplies, and an Amanero Combo384 USB to I2C Module
Project is going to be done in phases, so reduce cost in case I don't like the sound, etc.
However, due to shipping costs and delivery times, some items may have to be purchased together.
There are 3 main phases that I envision:
Without going into too much expense, I want to set-up a single Soekris dam1021 Rev 4 (0.012% resistor version) DAC board, with the intended 'audiophile grade' toroidal transformer, and the Amanero Combo384 USB to I2C Module.
Components:
:hase 2::
Building on Phase 1, now adding components for dual mono design, with separated and independent power supplies.
Components:
- Phase 1: Getting a 'taste' of the sound offered, and if it works for me compared to an of-the-shelf product
- Phase 2: Getting the dual-mono of the sound, and again checking if it works for me compared to an of-the-shelf product
- Phase 3: Getting a display and interface for the DAC.
Components:
- 1x Soekris dam1021 Rev 4 (0.012% resistor version) DAC board - Purchased, awaiting Delivery
- 1x Supreme Audio Grade Transformer TS10VA PRI:230V SEC:7VAC/7VAC toroidal transformer for Soekries board - Purchased 1, awaiting Delivery
- 1x Amanero-Hermes-Cronus Combo - 45.1584/49.152MHz Clocks [Amanero Combo384 Module USB Module + Hermes-AmaneroUSB Isolator Module + Cronus Re-clocking Module + 45.1584/49.152MHz Rhea Pair ] - Purchased, awaiting Delivery
- 2x Neutrik NC3MBH-B Gold Plated 3-Way PCB Mount XLR Male Connectors - To be purchased
- Hook-up wire - Transformer to DAC board: 15AWG Solid Core UPOCC Silver Wire - Purchased, awaiting Delivery
- Hook-up wire - USB to I2C Module to DAC board: 20AWG Solid Core UPOCC Silver Wire - Purchased, awaiting Delivery
- Case: 3D printed - Designed
- Kester 44 Rosin Core solder will be used
:hase 2::
Components:
- 1x Soekris dam1021 Rev 4 (0.012% resistor version) DAC board [2nd Soekries board]- Purchased, awaiting Delivery
- 1x Supreme Audio Grade Transformer TS10VA PRI:230V SEC:7VAC/7VAC toroidal transformer for 2nd Soekries board - To be purchased
- 1x Supreme Audio Grade Transformer TS10VA PRI:230V SEC:12VAC toroidal transformer for 3.3/5V AC-DC regulator board - To be purchased
- 1x Dual 5V/3.3V DC Regulator Board, 8-16V AC/DC Input (5V-3.3VReg) [replaces USB bus-power] - To be purchased
- 1x assembled input board kit from normundss of diyAudio - To be purchased/Emailed normundss, who indicated 2-3weeks build time.
- 1x assembled switch board kit from normundss of diyAudio - To be purchased/Emailed normundss, who indicated 2-3weeks build time.
- 1x additional input board parts for balanced build from normundss of diyAudio - To be purchased/Emailed normundss, who indicated 2-3weeks build time.
