koganm
Hi All,
I need some advise regarding the below speakers please. If you have owned them or have heard them, that would be a bonus. I know they are quite old but since I do not own a proper AVR system, this might be my first and is highly dependent on the feedback I receive here. Be blunt if needs be so I don't make a costly "beginner mistake".
P.S, I unfortunately cannot listen to the setup as it is out of Gauteng.
In addition, the wood veneer on one of the CM4's is beginning to peel. Is this a major issue? Can it be repaired or is this a sign of more damage to come?
- B&W CM4 - Rosewood
- B&W CM2 - Rosewood
- B&W CMC Centre - Rosewood
- B&W ASW 600
The above being driven by a Marantz SR 7300 - Gold, which is included in the deal.
Thanks in Advance
K
- B&W ASW 600
Thanks in Advance
K
