Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
General Discussion
Your input - Subwoofer placement.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Robert_E" data-source="post: 63165" data-attributes="member: 853"><p>If you can do a measurement of the sub with a pc and a mic you'll be able to see if some EQ might help cure the boomy-ness. I've got a sub in the corner and it's definitely not boomy, but that all depends on whats happening with the frequency response at the listening position and that's different for every room.</p></blockquote><p></p>
[QUOTE="Robert_E, post: 63165, member: 853"] If you can do a measurement of the sub with a pc and a mic you'll be able to see if some EQ might help cure the boomy-ness. I've got a sub in the corner and it's definitely not boomy, but that all depends on whats happening with the frequency response at the listening position and that's different for every room. [/QUOTE]
Insert quotes…
Verification
Post reply
General Discussion
