Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
General Discussion
Yamaha A520 & Separate Tuner or Pro-logic Amp
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="PAPPA3" data-source="post: 99321" data-attributes="member: 1199"><p>I think you've answered your own question. You already like the sound of your amp, so there's no need to upgrade that. It seems simpler and cheaper to just add a tuner. Note however what your future needs will be. If you'll be putting in a small satellite/sub combo for movies in your bedroom, an AVR should be considered.</p></blockquote><p></p>
[QUOTE="PAPPA3, post: 99321, member: 1199"] I think you've answered your own question. You already like the sound of your amp, so there's no need to upgrade that. It seems simpler and cheaper to just add a tuner. Note however what your future needs will be. If you'll be putting in a small satellite/sub combo for movies in your bedroom, an AVR should be considered. [/QUOTE]
Insert quotes…
Verification
Post reply
General Discussion
