Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
DIY & Tutorials
DIY For Audio
Who can design and/or build a quality valve amplifier?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Ampdog" data-source="post: 19181" data-attributes="member: 144"><p>Och! Did not notice this thread until recently.</p><p></p><p>Jamster, </p><p>Switch-mode not that much worse than for the hi-power car semi-conductor amps - they also use s-m. Remember that one will at least connect the heaters directly to 12V. I am not suggesting it is an option.... although I would like to have one in there just to have it on at night with them glowing valves visible to the outside world! Semi-conductor amps are so ....<em>invisible</em>!</p></blockquote><p></p>
[QUOTE="Ampdog, post: 19181, member: 144"] Och! Did not notice this thread until recently. Jamster, Switch-mode not that much worse than for the hi-power car semi-conductor amps - they also use s-m. Remember that one will at least connect the heaters directly to 12V. I am not suggesting it is an option.... although I would like to have one in there just to have it on at night with them glowing valves visible to the outside world! Semi-conductor amps are so ....[I]invisible[/I]! [/QUOTE]
Insert quotes…
Verification
Post reply
DIY & Tutorials
DIY For Audio
