Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
DIY & Tutorials
DIY For Audio
Vote: 6.5" Driver for bookshelf or small floorstander
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="chipwelder" data-source="post: 78583" data-attributes="member: 54"><p>Most people wont know there is no bass if you give them a little swell at 100Hz, especially if it is close to a wall... which is the only place you really put them - you just have to find a way to remove the midrange fudge and preferably make it image better courtesy of real absorbing next to the speaker on the wall... So i think a deep, small baffle speaker right at the wall, will probably fit the bill especially if you have big foam around it... <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite2" alt=";)" title="Wink ;)" loading="lazy" data-shortname=";)" /></p><p></p><p>You know those Little samson ipod speakers... they are actually quite decent, except for the tweeter, the midrange is often better than a lot of "better speakers", no real midbass though although a carefully placed and tuned port can sort that, and the low end must just not fudge up the mid. I suppose many people will go for that, for an ipod system as long as they can choose the colour. Not me, but I know those who would although for my desk that'd be nice...</p><p></p><p>P.s. then collaborate with someone to do a lm3886 in a small shiny case that is tuned for LOD input... or a slot on top... ;D</p><p></p><p>Oh ja for a 3" go single driver 4" go fer a two way... you are near as "full" range with a 3" eniewey</p></blockquote><p></p>
[QUOTE="chipwelder, post: 78583, member: 54"] Most people wont know there is no bass if you give them a little swell at 100Hz, especially if it is close to a wall... which is the only place you really put them - you just have to find a way to remove the midrange fudge and preferably make it image better courtesy of real absorbing next to the speaker on the wall... So i think a deep, small baffle speaker right at the wall, will probably fit the bill especially if you have big foam around it... ;) You know those Little samson ipod speakers... they are actually quite decent, except for the tweeter, the midrange is often better than a lot of "better speakers", no real midbass though although a carefully placed and tuned port can sort that, and the low end must just not fudge up the mid. I suppose many people will go for that, for an ipod system as long as they can choose the colour. Not me, but I know those who would although for my desk that'd be nice... P.s. then collaborate with someone to do a lm3886 in a small shiny case that is tuned for LOD input... or a slot on top... ;D Oh ja for a 3" go single driver 4" go fer a two way... you are near as "full" range with a 3" eniewey [/QUOTE]
Insert quotes…
Verification
Post reply
DIY & Tutorials
DIY For Audio
