Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
General Discussion
Vibration dampening for wall mounted speakers
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="KenMasters" data-source="post: 96571" data-attributes="member: 517"><p>REW is a free acoustic analysis program:</p><p></p><p>http://www.hometheatershack.com/roomeq/</p><p></p><p>You just need to register on the forum to download it. Once you've done that, just hook up your laptop to your reciever and use the signal generator to scale through frequencies until you hit the problem area. Much easier to troubleshoot the problem that way.</p><p></p><p>Felt might work, I don't know. I tried rubber feet first but they were too hard I guess and that didn't work, damping foam was my next stop. I figure anything with a bit of give that will absorb the vibration will work.</p></blockquote><p></p>
[QUOTE="KenMasters, post: 96571, member: 517"] REW is a free acoustic analysis program: http://www.hometheatershack.com/roomeq/ You just need to register on the forum to download it. Once you've done that, just hook up your laptop to your reciever and use the signal generator to scale through frequencies until you hit the problem area. Much easier to troubleshoot the problem that way. Felt might work, I don't know. I tried rubber feet first but they were too hard I guess and that didn't work, damping foam was my next stop. I figure anything with a bit of give that will absorb the vibration will work. [/QUOTE]
Insert quotes…
Verification
Post reply
General Discussion
