Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
Valves / Vacuum Tubes
Valve projects taking shape....
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Ampdog" data-source="post: 587824" data-attributes="member: 144"><p>OT:</p><p></p><p></p><p></p><p>Agreed. (These days marked with its American equivalent number: 5AR4) The GZ34 is quite more efficient than 5U4; same pin-out, and can be used with advantage in most 5U4 applications. Output voltage higher though, will have to be minded in some applications.</p></blockquote><p></p>
[QUOTE="Ampdog, post: 587824, member: 144"] OT: Agreed. (These days marked with its American equivalent number: 5AR4) The GZ34 is quite more efficient than 5U4; same pin-out, and can be used with advantage in most 5U4 applications. Output voltage higher though, will have to be minded in some applications. [/QUOTE]
Insert quotes…
Verification
Post reply
