Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
Valves / Vacuum Tubes
Strange intermittent noise from valve
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="charles" data-source="post: 959306" data-attributes="member: 2759"><p>"An ECC32 might be an interesting plug in.....don't tell the pensioners I said that!"</p><p></p><p>So true. A very rare valve that is the equivalent of the 6SN7. I have some but never used it.</p><p></p><p>Also a rare and an expensive valve. It was probably made in the 40/50's </p><p></p><p>Those early octal Mullard ECC types were:</p><p>ECC32: similar to 6SN7</p><p>ECC33: The rare one used in Leak 12 point one's</p><p>ECC34: low mu (11.5) triode </p><p>ECC35: similar to 6SL7</p></blockquote><p></p>
[QUOTE="charles, post: 959306, member: 2759"] "An ECC32 might be an interesting plug in.....don't tell the pensioners I said that!" So true. A very rare valve that is the equivalent of the 6SN7. I have some but never used it. Also a rare and an expensive valve. It was probably made in the 40/50's Those early octal Mullard ECC types were: ECC32: similar to 6SN7 ECC33: The rare one used in Leak 12 point one's ECC34: low mu (11.5) triode ECC35: similar to 6SL7 [/QUOTE]
Insert quotes…
Verification
Post reply
