Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
DIY & Tutorials
DIY For Audio
Simple SD DSTV PVR Cooling....
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Prince" data-source="post: 51104" data-attributes="member: 462"><p>8)</p><p></p><p>That's a good idea, but my decoder is under maintenance plan, so I will void that by opening the decoder. That's why, I just wanted an easy non-opening solution. </p><p></p><p>Let us know, if it works, when you try it.</p><p></p><p> ;D</p></blockquote><p></p>
[QUOTE="Prince, post: 51104, member: 462"] 8) That's a good idea, but my decoder is under maintenance plan, so I will void that by opening the decoder. That's why, I just wanted an easy non-opening solution. Let us know, if it works, when you try it. ;D [/QUOTE]
Insert quotes…
Verification
Post reply
DIY & Tutorials
DIY For Audio
