Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
DIY & Tutorials
DIY For Audio
Should I grease CD player drawer gear?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Crankshaft" data-source="post: 81580" data-attributes="member: 941"><p>Job completed.</p><p></p><p>The tray rails were very sticky. Cleaned off old grease with iso-alcohol, and relubed with some silicone grease. I left the gear unlubed. Works smooth and quiet.</p><p></p><p>I could see where the grease had absorbed into the previous gear - the plastic crumbled under my finger tips when pressed. The last time I replaced the gear, I had used Slick PTFE grease - it is obviously oil-based, so beware.</p></blockquote><p></p>
[QUOTE="Crankshaft, post: 81580, member: 941"] Job completed. The tray rails were very sticky. Cleaned off old grease with iso-alcohol, and relubed with some silicone grease. I left the gear unlubed. Works smooth and quiet. I could see where the grease had absorbed into the previous gear - the plastic crumbled under my finger tips when pressed. The last time I replaced the gear, I had used Slick PTFE grease - it is obviously oil-based, so beware. [/QUOTE]
Insert quotes…
Verification
Post reply
DIY & Tutorials
DIY For Audio
