Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
DIY & Tutorials
DIY For Audio
Seas project woes
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Timber_MG" data-source="post: 18054" data-attributes="member: 18"><p>A stiched leather insert for the baffle might work well glued to an actual baffle. Thick cardboard/shaped MDF with leather stiched onto it with sufficient tolerance to clear the drivers and whatever baffle mounting is desired.</p></blockquote><p></p>
[QUOTE="Timber_MG, post: 18054, member: 18"] A stiched leather insert for the baffle might work well glued to an actual baffle. Thick cardboard/shaped MDF with leather stiched onto it with sufficient tolerance to clear the drivers and whatever baffle mounting is desired. [/QUOTE]
Insert quotes…
Verification
Post reply
DIY & Tutorials
DIY For Audio
Seas project woes
