Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
General Discussion
Question on usb output
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="capetownwatches" data-source="post: 1015230" data-attributes="member: 19576"><p>Absolutely correct, in fact I think I need to use "YMMV" in my signature... ;D </p><p></p><p>The DAC I use for USB playback is a few years old and uses a VIA USB interface which is, shall we say, not the world's best out of the box.</p><p>It's taken a fair bit of tweaking to get it to perform optimally with my Windows PC.</p><p>Other newer implementations will likely be far more forgiving of USB3.</p><p></p><p>Note to self: try feeding the Concero (better USB interface) via USB3.0 and see what happens.</p></blockquote><p></p>
[QUOTE="capetownwatches, post: 1015230, member: 19576"] Absolutely correct, in fact I think I need to use "YMMV" in my signature... ;D The DAC I use for USB playback is a few years old and uses a VIA USB interface which is, shall we say, not the world's best out of the box. It's taken a fair bit of tweaking to get it to perform optimally with my Windows PC. Other newer implementations will likely be far more forgiving of USB3. Note to self: try feeding the Concero (better USB interface) via USB3.0 and see what happens. [/QUOTE]
Insert quotes…
Verification
Post reply
General Discussion
