Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
DIY & Tutorials
DIY For Audio
Power amp diagnostics / earthing advice: help needed
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="LAV" data-source="post: 73518" data-attributes="member: 1123"><p>Thanks guys, I really appeciate your help and advice, and Gert, no problem, you raise some valid safety points. I will have to take you up on that kind offer. I am stumped.</p><p></p><p>I am just not 100% convinced the problem is in the power amp. The only thing that has changed in this whole setup is thr power amp. My RB-1070 is not earthed (by design) and the RB-1080 is. Also, the 1070 does not have that 10 Ohm resistor between audio gnd. and chassis gnd, (they are directly connected) while the 1080 has. </p><p></p><p>The 991 and 1090 schematics should probably be very close to identical to that of the 1080 when it comes to the input circuitry and earthing arrangements,</p></blockquote><p></p>
[QUOTE="LAV, post: 73518, member: 1123"] Thanks guys, I really appeciate your help and advice, and Gert, no problem, you raise some valid safety points. I will have to take you up on that kind offer. I am stumped. I am just not 100% convinced the problem is in the power amp. The only thing that has changed in this whole setup is thr power amp. My RB-1070 is not earthed (by design) and the RB-1080 is. Also, the 1070 does not have that 10 Ohm resistor between audio gnd. and chassis gnd, (they are directly connected) while the 1080 has. The 991 and 1090 schematics should probably be very close to identical to that of the 1080 when it comes to the input circuitry and earthing arrangements, [/QUOTE]
Insert quotes…
Verification
Post reply
DIY & Tutorials
DIY For Audio
