Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
DIY & Tutorials
DIY For Audio
Power amp build
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="diyaudio" data-source="post: 901665" data-attributes="member: 14819"><p>sound quality aside as you already made it clear its NOT an issue. </p><p>in terms of one notch before catastrophic smoke. never mind sound quality.</p><p></p><p>This circuit is really bad and given the extreme operating voltages +/- 70VDC * 2, 140VDC, its very dangerous and destructive for the speakers which is probably more expensive than the whole amplifier assembled. </p><p></p><p>I would recommend you save your money and time build or buy an amplifier with more thoughtful protection like thermal, dc a zobel network and all the common stuff associated with a good amplifier. consciously it would probably sound good. </p></blockquote><p></p>
[QUOTE="diyaudio, post: 901665, member: 14819"] sound quality aside as you already made it clear its NOT an issue. in terms of one notch before catastrophic smoke. never mind sound quality. This circuit is really bad and given the extreme operating voltages +/- 70VDC * 2, 140VDC, its very dangerous and destructive for the speakers which is probably more expensive than the whole amplifier assembled. I would recommend you save your money and time build or buy an amplifier with more thoughtful protection like thermal, dc a zobel network and all the common stuff associated with a good amplifier. consciously it would probably sound good. [/QUOTE]
Insert quotes…
Verification
Post reply
DIY & Tutorials
DIY For Audio
Power amp build
