Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
General Discussion
Opinions on Pioneer system
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="gbyleveldt" data-source="post: 3092" data-attributes="member: 122"><p>@Musica,</p><p></p><p>My Marantz universal player also doesn't "support" DVD+ media, but I have a lot of stuff that works just fine. It does battle with the dual layer stuff though! One of them works, but the other one just says 'Disk Error'. These discs work fine in my cheapy Sony DVD player. I think the smaller Marantz (DV6600 I think) supports more formats, you might want to give that a look (albeit at R4500). The best is to take your DVD+ disk with when demoing just to check. If it works but is not technically supported, then I guess it'll be touch and go...</p></blockquote><p></p>
[QUOTE="gbyleveldt, post: 3092, member: 122"] @Musica, My Marantz universal player also doesn't "support" DVD+ media, but I have a lot of stuff that works just fine. It does battle with the dual layer stuff though! One of them works, but the other one just says 'Disk Error'. These discs work fine in my cheapy Sony DVD player. I think the smaller Marantz (DV6600 I think) supports more formats, you might want to give that a look (albeit at R4500). The best is to take your DVD+ disk with when demoing just to check. If it works but is not technically supported, then I guess it'll be touch and go... [/QUOTE]
Insert quotes…
Verification
Post reply
General Discussion
