1am7h30n3 said:
https://www.rtings.com/tv/reviews/lg/c1-oled/settings
Thanks! I ignored the calibration settings. The brightness is very high to my eyes so I run OLED pixel brightness on 0.
You did the right thing ignoring the white balance settings, they're unique to each set.
They recommend Expert Dark, but then tell you to set the gamma at 2.2 - this is wrong. What separates Expert Bright and Expert Dark is their gamma setting, Expert Dark is based around a gamma of 2.4, while Bright is oriented around 2.2
2.4 is the technically correct gamma for SDR content, but it is also based on the assumption you're watching content in dim lighting conditions. If you watch TV in a brighter room, you're better off with a gamma of 2.2.
They also recommend setting Peak Brightness to High, this is wrong for SDR, Peak Brightness should be left on the default Off. Its function is to boost the white sub-pixel for HDR use, it is not meant to be used with SDR content - it'll desaturate colours and drive your panel harder than is intended with SDR content.
Other than that, their recommendations are fine for SDR.
Looking at HDR, if you want the TV to track the PQ EOTF accurately, Auto Dynamic Contrast and Dynamic Tone Mapping should remain off. But as with using a gamma of 2.2 for SDR, if you view TV in a bright room, you may want to use Dynamic Tone Mapping, as it will lift the average picture level - thought I would still not recommend using Auto Dynamic Contrast.
On the motion settings, I would recommend leaving them all off, with the exception of Cinema Screen - this setting allows for proper 24fps playback.
