Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Registered members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Audio and Video Talk
The Vintage Audio Section
Old Amplifier and Relay Issue
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Steerpike" data-source="post: 786166" data-attributes="member: 807"><p>DM18 is there to monitor the presence of mains, and cut the speakers off as soon as AC mains is too low, or vanishes. If the amp did not do this sensing, you get a situation where the amp continues to operate on the charge stored in the power supply capacitors, for a minute or so after the mains is switched off.</p><p>They may have needed to make it more sensitive to low AC supply, and so modded the diode.</p></blockquote><p></p>
[QUOTE="Steerpike, post: 786166, member: 807"] DM18 is there to monitor the presence of mains, and cut the speakers off as soon as AC mains is too low, or vanishes. If the amp did not do this sensing, you get a situation where the amp continues to operate on the charge stored in the power supply capacitors, for a minute or so after the mains is switched off. They may have needed to make it more sensitive to low AC supply, and so modded the diode. [/QUOTE]
Insert quotes…
Verification
Post reply
